How to remote reboot a SA 540
Answered Question
Feb 1st, 2010
Hi All's
How can I reboot remotely a SA 540 device ?
I've got some Quick VPN users marked 'connect' but drop button is gray and users cannot connect anymore.
Correct Answer by Steven Smith about 7 years 3 weeks ago
Administration -> Firmware and Configuration -> Network...
At the bottom, there is a button for reboot.
Overall Rating: 5 (1 ratings)
Correct Answer
Steven Smith Mon, 02/01/2010 - 14:59
jamccord Tue, 02/02/2010 - 06:42
Please advise what version of firmware is on the SA540.
jason
Steven DiStefano Tue, 02/02/2010 - 12:44
Agree with you about Steven Smith.  He is the man, indeed.
Consider upgrading to the new FW though for the SA 500 router.   Fixed alot of issues.
Stephane.Guedon Tue, 02/02/2010 - 12:48
I've read release notes ... I can't do this operation from a remote site ... and this SA 540 a 800km far away from me.
Any solution ?
Steven DiStefano Tue, 02/02/2010 - 13:06
This was the last FW update that requirs factory reset.  Sorry about that.  There is nothing to do to overcome this.
William Childs Tue, 02/02/2010 - 22:18
Stephane,
You could try remote desktop or Log me in. I personally use log me in for my pcs at my home so I can remotely manage them from any network connection, and the best part is that it is free.
As always, a remote upgrade is not recommended. Therefore, having a person onsite when the upgrade needs to be performed would be a good idea. With remote desktop, you would be using a local computer to do the upgrade, only you would be remotely managing the computer; not the router.
Bill
Stephane.Guedon Wed, 02/03/2010 - 15:52
I was a good idea, even if once reset fixed IP address may be difficult ton configure for an end user ;)
I reboot SA 540 yesterday and ... it did not reboot !!! all leds but power one are off and impossible to get http interface on LAN .
Customer will send me the device ... hope I'll can do something.
Is the SA 540 a good device ? Previously this customer was working with a 871 PIX and no problem for 3 years
