WCS time settings are incorrect on application
Feb 1st, 2010
We have an issue with the time setting in the GUI of the WCS. The box is set with the right time but in the web interface, the time is 5h in advance.
I noticed this while creating a guest user acct, while editing time settings. The controller is not 5hours advance and has the correct time.
Is there a way for me to find out how WCS is configured with a time zome? WCS is installed on a Windows 2008 Server.
John
satcomjimmy Wed, 02/03/2010 - 06:28
What version code are you running? I remember this as being a known issue that was
fixed, but my memory is sketchy.
johncomeau Fri, 02/05/2010 - 17:15
hey thanks for your response. the version of WCS that im running is 5.2.148.0
i still cant seemed to resolved this.
Thanks for any information that you think you can add.
braggb001 Fri, 02/12/2010 - 08:32
John....
     This is per Cisco:
Set Up NTP on the  WCS
The WCS relies on Windows or Linux for the correct time. The WCS checks       the Windows Operating System or the Linux Operating System once every 24 hours       for the system time. Therefore, it does not immediately know about system time       changes unless you stop and restart the WCS server. Right-click on the clock       and select Adjust Date/Time. Use an NTP time source to set the       clock and manually set the offset for your time zone. This is typically already       set.
RICH FRUEH Mon, 01/10/2011 - 13:12
How did you get it installed on 2008, since the installer doesn't allow it to install?
Related Content
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
