Warning message
Cisco 6500 series Virtual Firewall
Feb 1st, 2010
Dear all firewall gurus,
It's my first time to use 6500 series Virtual Firewall for my clients.  Does anyone have any sample config that I can use as reference?? I have a pair of 6509 running VRRP and needs to have virtual firewall on top.
Would appreciated any help  =)
Cheers,
Hunt
Jon Marshall Tue, 02/02/2010 - 01:19
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Cheers,
Hunt
Hunt
It's not entirely clear what example you are looking for. Have a look at this and come back if you have further questions or if this is not what you were looking for -
FWSM multi context configuration
Jon
Ganesh Hariharan Tue, 02/02/2010 - 02:20
  • Purple, 4500 points or more
  • Community Spotlight Award,
    Member's Choice, February 2016
Cheers,
Hunt
Hi Hunt,
Your requirement is not clear what you want to achive with FWSM like single or multiple context with redundancy of firewall,Anyway just check out the belowlink on FWSM configuration.Hope to help !!
http://www.cisco.biz/en/US/products/hw/modules/ps2706/products_configuration_example09186a00808b4d9f.shtml
If helpful do rate the post
Ganesh.H
