Cisco Aironet 1142N at elementary school
Feb 1st, 2010
Hi. We're having a tough time at a couple of elementary schools that are using a number of Cisco products which we got through a deal with AT&T. I really hope you can give us some guidance. Here's our situation: We have an elementary school equipped with about eight Cisco Aironet 1142N access points. Signals go to 3 stacked switches (Cisco Catalyst 3750 PoE-48) and are managed via a Cisco wireless LAN controller (NME-AIR-WLC12-K9).
We are having significant bandwidth problems. If we get more than 12 laptops (we've got a "mobile Macintosh lab") simultaneously online, the network freezes.We can't even get more than 15 iTouches online simultaneously.
Here's the rest of the setup: our *elementary* school is connected via fiber (probably 10MB) to the *intermediary* school and then to the district office. The district office is connected to the Internet (county depart of Ed is officially the ISP; AT&T is the service provider).  The AT&T link may be 6MB.At the *intermediary* school the data traffic for the mobile Macs is    handled by an /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:12.0pt; font-family:"Times New Roman"; mso-ascii-font-family:Cambria; mso-ascii-theme-font:minor-latin; mso-hansi-font-family:Cambria; mso-hansi-theme-font:minor-latin;} Apple Xserve workgroup server.
The XServers are for Directory Services only (log in authentication for the MacBook Labs). There is one Open Directory Master at the intermediary school, and an Open Directory Replica at each site. A LightSpeed Total Traffic Control Server does content filtering for us. There are also about 5 Cisco (Windows-based) servers helping manage data at the intermediary school (VOIP and Wifi traffic only).The rest of the traffic (internal, wired ethernet) is handled by the Cisco switches and controllers; for external traffic - after the controllers it goes to the LightSpeed Traffic Control server then out the Cisco FireWall.
Sorry to dump all that on you, but candidly since we installed the Aironets in September we haven't really been able to effectively use the mobile Mac lab. Ideally we'd like to be able to run about 30 laptops simultaneously. They don't have to get video -- just google searches would be a start.
We should also note that at this elementary school, we have 4 wifi networks running different VLANs available through the Aironets. The one that has the most problems is the one I've described above -- it's supposed to be for student access. We have a teacher-only network that does NOT seem to have the same bandwidth constraints as the student network. We also Cisco VOIP phones all over the school, but use of the phones is modest.
What we’d like to know:
1.     Is it likely that we have an insufficient number of access points or that that those access points can’t handle? If so, is the problem likely that we need more access points? (and if that's true, why is the teachers' network ok?)
2.     Is the problem more likely at the server or switch choke point?
3.     Is it likely that the problem involves Student accounts rather than teacher accounts? Why would this be so?
4.     What are the best ways to test what’s causing our choke points?
Thank you for your help!!!
George Stefanick Tue, 02/02/2010 - 20:21
Hello!
For reliable data you dont want to have a signal greater then -76ish. The higher the number the further you are away from
the access point. So lets start there first. In the area you are having trouble are you lower then -76. Keep in mind, you want
want to check this when you have a full class door closed.
Unless you are pulling down video all at the same time i would suspect no.
I always say, "follow the packet". Lets look at the wireless side first and then venture in. Are you doing any bandwith limiting ?
Like i mentioned, lets see what we have on the wireless side. Can you reproduce the problem !?
lincolnbsd Thu, 02/04/2010 - 11:17
Hi there. Thanks for your note.
1. the RSSi seems fine (running below -69 even in classrooms where there isn't an Aironet in the room but instead located next door).
2. we're *not* using any video
3. no bandwidth limiting going on
4. the problem reproduces itself all the time! we have the same problem using say, more than15 ipod Touches or Macbooks.
You say "follow the packets" which sounds like a great idea. How do we do that? Is there diagnostic software that would work with our configuration that would let us test this? Or what other collection of questions should we be asking to try to isolate the problem?
ec
George Stefanick Thu, 02/04/2010 - 17:31
A few questions...
What channels do your access point use?
Have you had a professional site survey?
Are you using "aggressive load balancing" under controller tab
That 15th client that cant get on, can you drop down into the CLI and do a debug on the clients that cant get on?
Leo Laohoo Thu, 02/04/2010 - 13:23
Are you sure or can you elaborate?  Does your WLAN come to a halt or does the wired LAN gets affected too?
I am currently working for the state's education department and I manage >300 autonomous and controller-based AP.
jwarner Sat, 02/06/2010 - 16:59
Your post doesn't say that you're using NAT for address expansion.  But elementary schools often do.  Could inability to get more computers on the network be due to an address limitation in the NAT server?
To tease apart capacity and server limitations, you might want to run one of the popular net test speed checks.  Ours is at http://nitro.ucsc.edu but there are others.  DSLreports comes to mind.  You would test the net for its intrinsic speed early in the morning when the network at your school and the upstream middle school are idle.  You would then repeat the test when things bog down.  If you can still get reasonable performance, that points to DNS or NAT problems rather than actual capacity or problems in the wireless domain.
lincolnbsd Tue, 02/09/2010 - 17:41
Thanks all for your comments. Here are some responses as well as our current "plan of action." I'd VERY MUCH welcome any additional suggestions that you have about the test we're going to run (probably next Tue).
1. Channel: the site operates on Channel 1 (2.4 Ghz)
2. Professional site survey: no: AT&T is supposed to do it at some point as they're our ISP. But that hasn't yet happened. No idea when it might.
3. Aggressive load balancing?  We don't know as AT&T has that info.
4. 15th client... Once we exceed 15 clients, access for all clients grinds to a halt. The slowdown is a pretty steep curve (not quite a cliff) for 15 clients when we use iPods; it begins at 12 clients or so when we use Macbooks.
5.    /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:12.0pt; font-family:Cambria; mso-ascii-font-family:Cambria; mso-ascii-theme-font:minor-latin; mso-hansi-font-family:Cambria; mso-hansi-theme-font:minor-latin;} Does your WLAN come to a halt or does the wired LAN gets affected too?
When we experience these problems, the teachers’ wireless LAN is unaffected. The only place we’re experiencing the slowdown is on the wireless LAN that’s used by the students. We have a “computer lab” with a wired network of about 30 PCs. (Ethernet CAT 5 to fiber on the way out of the building). This is a separate VLAN from the (student) wireless VLAN. When the student wireless VLAN stalls, it DOES NOT affect either the wired VLAN or teacher network. We do experience slowdowns on the WIRED student VLAN but no where as severe as on the WIRELESS VLAN. (In other words, we can run all 30 wired PCs on the wired LAN).
6. Could inability to get more computers on the network be due to an address limitation in the NAT server?
No. We have a big, big address range.
Here's our current plan: we're going to VERY CAREFULLY chronicle the drop off in usage at several points during the day:
8:00 am (no students)
10:00 am (busy school but probably not much student wifi usage)
noon: we'll run a test with +15 students using laptops and measure the bandwidth using a network speed checker at every point. That way, we figure we'll have a clearer chart of the usage breakdown.
Does anyone have any suggestions of addition things we should monitor during this test? We're going to do it next Tue (2/19).
In addition, if there are any specific questions that we should put to AT&T, I'd love to hear them.
Thank you all!!
Related Content
