ip host command
Answered Question
Feb 2nd, 2010
in routers we can use the "ip host " command to map name to IP.
is there an equivalent command for firewalls?
Correct Answer by Jon Marshall about 6 years 11 months ago
You can use the "name" command which allows you to associate a name with an IP in the config -
http://www.cisco.com/en/US/docs/security/asa/asa72/command/reference/no_72.html#wp1652055
note that this is nothing to do with DNS mappings, it is just a handy way to have meaningful names in your config.
Jon
Overall Rating: 5 (1 ratings)
Correct Answer
Jon Marshall Tue, 02/02/2010 - 01:15
Jon
ohassairi Tue, 02/02/2010 - 01:30
thank you jon
so there is no way to do  DNS map using commands ?
