SA540 SSL connection
Feb 2nd, 2010
Hi all,
Another problem with SA540: To establish an SSL connection with Firefox, I use both the ver 3.5 and 3.6. I found it work quite well with 3.5. But with 3.6, after I clicking the icon to download the software, it just block, no message is shown. The settings on 3.5 and 3.6 are same. Does it mean the SSL is not supported by Firefox 3.6? Any help will be appreciated.
P.S. Is it possible to use a client-end software to establish the SSL connection on SA540?
Steven Smith Tue, 02/02/2010 - 09:34
  • Gold, 750 points or more
Currently, there is not client to start a SSL connection yet.  I just upgraded firefox from 3.5.7 to 3.6 and didn't have any issues getting my SSL VPN to come up.  Can you verify that you are logged in as an administrator?
kddifr2006 Tue, 02/02/2010 - 10:22
Thank you for reply. I'm login as administrator. And I've tried on two laptops, their os are windows XP, both can't work with Firefox 3.6.
Steven Smith Tue, 02/02/2010 - 13:46
Can you give a screen shot of the block you are seeing?
kddifr2006 Wed, 02/03/2010 - 00:30
No message is shown. Only the browser begin to charging the page and after 2 or 3 seconds it end the charging process.
Related Content
