02-02-2010 02:02 AM - edited 03-15-2019 09:16 PM
Debug voice ccapi inout is attached.
The numbers as follows:
Originating number: +86 – 212 – 850 – 7205
Destination Number: +65 – 6215 – 7878
Voice Gateway has E1 controllers 1/0, 1/1, 2/0 and 2/1.
When calls are established via 1/0 or 1/1 the call setup is fine, but dead air in both directions – no voice. But when calls are established cia 2/0 or 2/1 everything works fine and there is no problem. These 4 x E1 lines connect to a PBX. So temporarily 1/0 and 1/1 are shut down as a work-around and all OK. These were all working before and there has been no config or IOS change. So we ssuspect H/W failure.
Slot 1 and 2 of this Cisco 3745 router has High Density Voice Adapter Module P/N 800-03567-01 with E1 (2 Port) Multi-Flex Trunk (Drop&Insert) WAN Daughter Card.
Partial config of the router:
dial-peer voice 9999 voip
application session
destination-pattern .......
voice-class codec 1
session protocol sipv2
session target dns:net.abc.def.com
dtmf-relay rtp-nte
icpif 25
ip qos dscp ef signaling
no vad
dial-peer voice 1 pots
description 8 digits because sip proxy inserts 1
destination-pattern ........
progress_ind alert enable 8
no digit-strip
direct-inward-dial
port 1/0:15
forward-digits 7
dial-peer voice 2 pots
no digit-strip
direct-inward-dial
port 1/1:15
forward-digits 7
dial-peer voice 3 pots
no digit-strip
direct-inward-dial
port 2/0:15
forward-digits 7
dial-peer voice 4 pots
no digit-strip
direct-inward-dial
port 2/1:15
forward-digits 7
02-02-2010 02:12 AM
Forgot to add dial peer voice 999 ( triple 999 ) but 9999 dial pe
er already added.
dial-peer voice 999 voip
description default inbound matching dial-peer
voice-class codec 1
incoming called-number .
dtmf-relay rtp-nte
icpif 25
no vad
The debugs were done when E 1/0 first and then E1/1 were temorarily enabled and calls were established from and to the numbers stated in the previous entry
02-02-2010 02:19 AM
Do you have NAT or Firewall devices in path between routers ?
02-02-2010 03:38 AM
I am yet to understand the debug voice ccapi inout, but there is the show voice dsp cpmmand done twice as indicated in the attached file. These two successive show voice dsp commands were done during teh dead air connected call.
I notice:
The first time show voice dsp showed - partial output without showing all idle DSPs
DSP DSP DSPWARE CURR BOOT PAK TX/RX
TYPE NUM CH CODEC VERSION STATE STATE RST AI VOICEPORT TS ABORT PACK COUNT
C549 001 01 g729r8 4.4.702 busy idle 0 0 1/0:15 01 0 535950174/46
2204615
02 {medium} 4.4.702 IDLE idle 0 1/0:15 02 0 116573250/11
8555215
C549 008 01 {medium} 4.4.702 IDLE idle 0 0 1/0:15 30 0 0/11651
02 g729r8 4.4.702 busy idle 0 1/0:15 31 0 0/44115
The second time show voice dsp showed - partial output without showing all idle DSPs
C549 001 01 g729r8 4.4.702 busy idle 0 0 1/0:15 01 0 535954017/46
2208522
8555215
02 g729r8 4.4.702 busy idle 0 1/0:15 31 0 0/48018
See the RED - counters for TX PACK CNT remain 0.
02-02-2010 04:08 AM
bevilacqua,
Using E1 controllers 2/0 and 2/1 on the same Cisco 3745 everything works fine. But when using E1 controllers 1/0 and 1/1 causes the problem of dead air in both directions after call sets up successfully.
I don't think this is a NAT FW issue between router and the network if you are thinking of RTP packets being dropped by FW.
02-02-2010 05:11 AM
Have you tried reloading the router ?
02-07-2010 04:48 PM
NM-HDV2E160 in Slot 1 ws replaced and the problem got resolved. I am sure if we had just changed the DSP in slot 2 of this card that would have resolved too, but we had pressure from customer to fix in one go.
