vpn ipsec Cisco 877 <-> iphone
Answered Question
Feb 2nd, 2010
Hi, I'm trying to set up ipsec vpn between my cisco 877 and iphone/cisco vpn client. First, what's difference between remote access vpn and easy vpn setup ? The phase1 and phase2 are completed but I have no traffic between peer.
Maybe I miss something conf ? Should I add route map with acl 101 ?
These are the configuration relative isakmp/ipsec.
crypto isakmp enable
crypto logging session
crypto isakmp policy 10
encr 3des
hash md5
authentication pre-share
group 2
lifetime 3600
crypto isakmp keepalive 10
crypto isakmp nat keepalive 20
crypto isakmp xauth timeout 90
crypto isakmp client configuration group remote-vpn
key password
dns 212.216.112.112
domain cisco877.local
max-users 10
max-logins 10
pool remote-pool
acl 150
save-password
crypto ipsec transform-set VPN-CLI-SET esp-3des esp-md5-hmac
crypto ipsec security-association idle-time 3600
crypto dynamic-map remote-dyn 10
set transform-set VPN-CLI-SET
crypto map remotemap local-address dialer0
crypto map remotemap client authentication list userauthen
crypto map remotemap isakmp authorization list groupauthor
crypto map remotemap client configuration address respond
crypto map remotemap 65535 ipsec-isakmp dynamic remote-dyn
interface dialer0
ip local pool remote-pool 192.168.69.0 192.168.69.20
ip route 192.168.69.0 255.255.255.0 dialer0
no access-list 150
access-list 150 rem *** ACL split tunnel ***
access-list 150 permit ip 10.0.77.0 0.0.0.255 192.168.69.0 0.0.0.255
no access-list 101
access-list 101 remark *** ACL nonat ***
access-list 101 deny ip 10.0.77.0 0.0.0.255 192.168.69.0 0.0.0.255
access-list 101 permit ip 10.0.77.0 0.0.0.255 any
Should I apply this acl 101 to Loopback?  Ex:
ip nat inside source list 101 interface Loopback0 overload
Should I apply a permit acl like access-list  169 permit ip 192.168.69.0 0.0.0.255 any in my Dialer 0 interface ?
Any other tips ? Best regards.
Correct Answer by pudawat about 7 years 1 month ago
Hi Alessandro,
The split tunnel access list is fine!
If you are doing NAT on public and private interface i.e. ip nat inside and ip nat outside etc
you need to add the command ip nat inside source list 101 interface Dialer0 overload
Or you can create a new route map
route-map new permit 10
     #match acl 101
command: ip nat inside route-map interface Dialer0 overload
Pradhuman
Overall Rating: 5 (1 ratings)
Correct Answer
pudawat Tue, 02/02/2010 - 16:09
Hi Alessandro,
     #match acl 101
Pradhuman
alessandro.fachin Wed, 02/03/2010 - 01:00
thanks a lot for you reply. I add the command "ip nat inside source list 101 interface Dialer0 overload" on my Dialer0 interface, perhaps it still doesn't work.
If I try with my iphone ( 3G ) in succesfully connect but I still can't ping my remote lan.
If I try with vpnc ( linux box ) I get "NAT status: this end behind NAT? YES -- remote end behind NAT? no
vpnc: no response from target". I guess that net-traversal is alredy active, how could I check that ?
I'll show you also my nat configuration, maybe is something wrong there:
interface Vlan1
     ip nat inside
     ip access-group 180 in      (permit any any)
      ip access-group 180 out  (permit any any)
interface Dialer0
     ip nat outside
     dialer pool 1
dialer-group 1
ip nat pool pool1 10.0.77.0 10.0.78.0 netmask 0.0.0.255
ip nat inside source list 1 interface Dialer0 overload
access-list 1 permit 10.0.77.0 0.0.0.255
dialer-list 1 protocol ip permit
dialer-list 2 protocol ip permit
Thanks for help!
alessandro.fachin Wed, 02/03/2010 - 01:45
Now I have enable also traffic for 4500 udp (nat-traversal) and I finally get able to connect also with my linux client (vpnc) but I'm still not enable to ping the lan. In router 800 exists a command like in cisco asa:
asa sysopt connection permit-vpn
asa sysopt connection permit-ipsec
that permit all traffic ?
These are a little sniff with tcpdump while I try to ping my lan:
Encrypted on eth0
10:38:34.572398 IP 87.4.235.243.4500 > 192.168.0.67.4500: UDP-encap: ESP(spi=0xbf208db4,seq=0x3a), length 116
10:38:35.462008 IP 192.168.0.67.4500 > 87.4.235.243.4500: UDP-encap: ESP(spi=0x9bba49aa,seq=0xf), length 116
10:38:35.541143 IP 87.4.235.243.4500 > 192.168.0.67.4500: UDP-encap: ESP(spi=0xbf208db4,seq=0x3b), length 116
10:38:36.462011 IP 192.168.0.67.4500 > 87.4.235.243.4500: UDP-encap: ESP(spi=0x9bba49aa,seq=0x10), length 116
10:38:36.536791 IP 87.4.235.243.4500 > 192.168.0.67.4500: UDP-encap: ESP(spi=0xbf208db4,seq=0x3c), length 116
10:38:37.464486 IP 192.168.0.67.4500 > 87.4.235.243.4500: UDP-encap: ESP(spi=0x9bba49aa,seq=0x11), length 116
10:38:37.574281 IP 87.4.235.243.4500 > 192.168.0.67.4500: UDP-encap: ESP(spi=0xbf208db4,seq=0x3d), length 116
Decrypted on tun0:
11:45:21.731816 IP 192.168.69.11 > 10.0.77.13: ICMP echo request, id 39700, seq 3, length 64
11:45:21.795466 IP 87.4.235.243 > 192.168.69.11: ICMP echo reply, id 39700, seq 3, length 64
11:45:22.731744 IP 192.168.69.11 > 10.0.77.13: ICMP echo request, id 39700, seq 4, length 64
11:45:22.852398 IP 87.4.235.243 > 192.168.69.11: ICMP echo reply, id 39700, seq 4, length 64
11:45:23.731778 IP 192.168.69.11 > 10.0.77.13: ICMP echo request, id 39700, seq 5, length 64
It seems that router reply with public ip instead of private ip. It seems is a nat problem!
[email protected]:/etc/vpnc# ping 10.0.77.13
PING 10.0.77.13 (10.0.77.13) 56(84) bytes of data.
^C
--- 10.0.77.13 ping statistics ---
22 packets transmitted, 0 received, 100% packet loss, time 21057ms
alessandro.fachin Thu, 02/04/2010 - 08:17
Problem is solved, there was thow acl on nat Dialer0. Remove the first permit of acl 1, now the traffic arrive correctly with private ip ( not with the public).
etmarcof Thu, 07/15/2010 - 02:49
Hi Alessandro,
I'm trying to do the same config as you.
What IOS version of router you have in 877?
I saw that minum version to work should be 14.4.(15)T.. Is these really necessary?
Best Regards
MC
alessandro.fachin Sat, 07/17/2010 - 06:26
the version is:
Cisco IOS Software, C870 Software (C870-ADVIPSERVICESK9-M), Version 15.0(1)M, RELEASE SOFTWARE (fc2)
Related Content
