fast busy tone after transferring externals calls
Feb 2nd, 2010
i use CCM 7.0 and H323 gateway cisco 2811. internal call forwarding works fine.
From my ip phone, i call my cell phone then i try to transfer the call to another cell phone so the 2 cell phones can reach each other, after pushing transfer softkey botton i heard a fast busy tone in my cell phone.
the attach file contain the sh run of my Gateway
any ideas
thx in advance
Rob Huffman Tue, 02/02/2010 - 05:44
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Bilal,
Try this Service Parameter under CUCM "Block External-to-External Transfer"
make sure it is set to "False".
Cheers!
Rob
Criss Sawyer Tue, 02/02/2010 - 06:58
hi rob,
thank you for your response.
Did you mean /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Tableau Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-priority:99; mso-style-qformat:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:11.0pt; font-family:"Calibri","sans-serif"; mso-ascii-font-family:Calibri; mso-ascii-theme-font:minor-latin; mso-fareast-font-family:"Times New Roman"; mso-fareast-theme-font:minor-fareast; mso-hansi-font-family:Calibri; mso-hansi-theme-font:minor-latin;} Block OffNet To OffNet Transfer ?
if yes, this service is already set to "false"
In my environement, i have CCM 7.0 and 2 gatways h323 3825 and 2811 (all within same Vlan). the 2 gateways are configured the same way but the call transfer works fine with the 3825 gateway but it does not with the 2811 one.
