Warning message
CUCM 7 unified Serviceability issues
Feb 2nd, 2010
Hi All
I sure could use some help...
Just finished installing the second CUCM7 as a subscriber, all went ok. However when i try yo go to the Cisco Unified Serviceability it always comes up with
HTTP Status 404 - /ccmservice/
type Status report
message /ccmservice/
description The requested resource (/ccmservice/) is not available.
Apache Tomcat/5.5.27
Any help on this will be appreciated
Okechi
markbatts Tue, 02/02/2010 - 05:02
  • Bronze, 100 points or more
Can you access any web pages from the subscriber eg administrator , os etc?
mark
Okechi Awujo Tue, 02/02/2010 - 05:09
Hi Mak,
Yes I can access every other link---- cm administration, disaster recovery, OS administration.  execpt serviceability
ta
Okechi
Jonathan Schulenberg Tue, 02/02/2010 - 06:26
  • Cisco Designated VIP,
    2017 IP Telephony
This is unlikely but perhaps that Tomcat application failed to start. You can check this through the OS CLI using SSH:
admin:utils service list
Requesting service status, please wait...
...output truncated...
Cisco CallManager Serviceability[STARTED]
Cisco CallManager Serviceability RTMT[STARTED]
If either of those show STOPPED, you can try starting them with utils service start
Okechi Awujo Tue, 02/02/2010 - 07:45
Checked the services all started..
System SSH [STARTED]
Cluster Manager [STARTED]
Service Manager is running
Getting list of all services
>> Return code = 0
A Cisco DB[STARTED]
A Cisco DB Replicator[STARTED]
Cisco AMC Service[STARTED]
Cisco CAR Scheduler[STARTED]
Cisco CDP[STARTED]
Cisco CDP Agent[STARTED]
Cisco CDR Agent[STARTED]
Cisco CDR Repository Manager[STARTED]
Cisco CallManager Admin[STARTED]
Cisco CallManager Cisco IP Phone Services[STARTED]
Cisco CallManager Personal Directory[STARTED]
rupam_chakra1983 Wed, 01/26/2011 - 05:06
Hi Friends
I am also facing the same issue...
Kindly let me know if you find a solution..
srsivara Wed, 01/26/2011 - 05:47
  • Cisco Employee,
Can you run 'utils diagnose test' on SSH session to the Sub, and check if all the tomcat checks pass ?
I would also try restarting tomcat (utils service restart Cisco Tomcat) on the Sub, wait for Cisco Tomcat to start back up, and check the serviceability page again.
- Sriram
Please rate helpful posts !
