AP 521 console configuration
Feb 2nd, 2010
Hi.
I have a Cisco 521 Acces Point - the standalone version.
It had some problems with the IOS and I made an up-grade.
It is now running the latest version: 12.4
I cannot configure the Acces Point from the web interface - most of the pages are missing or giving me script errors,
so I started to configure the AP fom console interface (via serial cable).
The network design is simple:
192.168.0.1 - a Linksys RV042 router acting as gateway, DHCP server and DNS proxy.
192.168.0.2 - Cisco 521 Acces Point
192.168.0.3 - Cisco Catalyst 2960 switch
Starting from 192.168.0.10 up to .100 I have a DHCP IP address range.
Below you can see the acces point configuration:
Building configuration...
Current configuration : 1576 bytes
version 12.4
no service pad
service password-encryption
hostname Aironet
enable secret 5 $1$bTcL$bxwAydUMKA4z0TXcMgEf6/
enable password 7 033E0B190D0301424A
no aaa new-model
ip name-server 192.168.0.1
ip dhcp smart-relay
ip dhcp relay information policy keep
ip dhcp-server 192.168.0.1
dot11 ssid ServiceCenter
   authentication open
   authentication key-management wpa version 2
   guest-mode
   wpa-psk ascii 7 012003164D02050A0249401D1C17
power inline negotiation prestandard source
username Cisco password 7 13261E010803
username admin privilege 15 password 7 0735715E4505390B13
bridge irb
interface Dot11Radio0
no ip address
no ip route-cache
encryption mode ciphers tkip
ssid ServiceCenter
station-role root access-point
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
bridge-group 1 spanning-disabled
interface FastEthernet0
no ip address
no ip route-cache
duplex auto
speed auto
bridge-group 1
interface BVI1
ip dhcp relay information trusted
ip address 192.168.0.2 255.255.255.0
ip helper-address 192.168.0.1
no ip route-cache
ip default-gateway 192.168.0.1
ip http server
no ip http secure-server
ip http help-path
http://www.cisco.com/warp/public/779/smbiz/prodconfig/help/eag
bridge 1 route ip
line con 0
line vty 0 4
login local
end
Here are the two problems I am facing:
1. Clients can associate to the wireless network (I see the message on the command line of the AP) but cannot get an IP addres by DHCP
2. When I set up an IP address manually (eg. 192.168.0.5/25, GW: 192.168.0.1, DNS: 192.168.0.1) on a computer connected to the wireless network, I can only ping the AP.
From the command line of the AP I can succesfully ping all the network devices (router, switch, printers, etc) and also I can ping the computer connected via wireless with the IP manually set up.
Please take a look at the configuration and tell me what can I do.
Related Content
