Dial Intercom Group [CUCM 7.0]
Feb 2nd, 2010
Is it possible to configure a Dial Intercom Group in CUCM 7.0 ... versus Intercom which allows you to place and receive one-way calls using dedicated intercom lines [auto answer with speakerphone].
What we would like to be able to do ... arrange a group of 20 phones into a dial intercom group. Want to be able to call another set in the dial intercom group by dialing a one or two digit code.
  1. Pick up the handset and press the Intercom key.
  2. Dial a one or two digit code for the phone you are calling.
  3. Wait for auto-answer; you are then connected.
Thanks.
Jonathan Schulenberg Tue, 02/02/2010 - 08:46
  • Cisco Designated VIP,
    2017 IP Telephony
Sure. Remember that the intercom lines exist in their own partition and have their own CSS. You can create two-digit intercom directory numbers and place them all in the same intercom partition. Assign a CSS that has only that partition. Do not specify a speed dial value on the intercom line when you create it. When the user goes off-hook, they will receive dial tone and can enter the two-digit intercom directory number of another person in that partition.
