Unity Connection Notification
Answered Question
Feb 2nd, 2010
Does anyone know of a way to send a notification to Email (Group Wise) of a voicemail without sending the actual message? Basically I have set it up so that Unity Connection will send an email to my Groupwise email account and it works, but we don't want the attached .wav file. Is there a better way to send a notification of a voicemail then what I am using?
Correct Answer by Bradford Magnani about 6 years 8 months ago
Sounds like you may have Accept and Relay feature configured?  You may want to look into SMTP Notifications:
Hope that helps,
Overall Rating: 5 (1 ratings)
Mybabesx2 Thu, 02/04/2010 - 08:22
Thank you for your response. It was exactly what I was looking for.
