UC500 Phone "Deceased"
Answered Question
Feb 2nd, 2010
I am currently working an issue in which an ephone status show "deceased".  This particular phone has been "deceased" 3 times in the last 3 months, and no other phone has experienced any issues.  This phone is running off a small switch which is getting it's link from a fiber to copper transceiver.
Any thoughts?  Or info about why the phone is deceased?
Jeff
Correct Answer by Marcos Hernandez about 7 years 5 months ago
DECEASED status indicates that the connection to the Cisco Unified IP phone was closed because of a keepalive timeout. You have a connectivity problem that needs to be fixed.
Marcos
Correct Answer by Steven Smith about 7 years 5 months ago
Deceased means the phone unregistered due to a keep alive timeout.  Unfortunately, it probably means a network problem.  I would check cabling, the switches, and everything in between the devices.  You might try upgrading the phone firmware, but that is really a shot in the dark.
Overall Rating: 5 (2 ratings)
Correct Answer
Steven Smith Tue, 02/02/2010 - 08:16
  • Gold, 750 points or more
Correct Answer
Marcos Hernandez Tue, 02/02/2010 - 08:16
  • Blue, 1500 points or more
Marcos
jeffrey-young Tue, 02/02/2010 - 10:05
Thank you Steven and Marcos for the fast response.....
I appreciate it
Jeff
MICHAEL JOHNSON Thu, 04/29/2010 - 14:02
  • Bronze, 100 points or more
What if the "phone" changes? Could the ESW switch be bad? We have had this happen 4 times in less than a week to 4 different phones. Only pattern is same ESW switch.
Is there a way to UP the keep-alive?
Ray Long Sat, 05/01/2010 - 00:15
The default keepalive setting for ephones and telephony-service is 30 secs. If configured in ephone config mode, this keepalive setting takes priority over the global telephony-service keepalive.
From the CME command reference http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/command/reference/cme_k1ht.html
The following example sets the ephone keepalive interval to 300 seconds:
Router(config)#ephone  1
Router(config)#keepalive 300
or
The following example sets the telephony-service keepalive time interval to 40 seconds:
Router(config)#telephony-service
Router(config-telephony)#keepalive 40
