02-02-2010 09:18 AM - edited 03-11-2019 10:04 AM
Has anyone experienced problems changing the logging severity level of a Syslog ID to either raise or lower its level within the ASDM? I want to log certain activities that are currently set as notification and informational but don't want to log everything at that level. I thought that I might try changing the severity level of the IDs I want to capture as a work around, any suggestions? Thank you.
Solved! Go to Solution.
02-02-2010 01:55 PM
Hi James
what do you want to log here ? Some specific traffic (info or notifications ) ? If so, see if this URL helps you:
http://www.ciscopress.com/articles/article.asp?p=424447&seqNum=3
It basically talks about pruning certain log messages and customizing your log messages.. if you want specific logging from a source to destination, your ASA access-lists can include "log" keyword which can show you similar outputs..
Hope this helps.. all the best
Raj
02-02-2010 01:55 PM
Hi James
Raj
02-04-2010 12:10 PM
I finally got a chance to take a look at the link and found what I needed. Thank you.
