Difference between SUP-6-E and SUP-6-E lite
Answered Question
Feb 2nd, 2010
Hi all,
I'm trying to configure a Catalyst 4507R with a Supervisor 6E but I noticed there is another Supervisor 6E lite. I can't find information about the "lite" version of this supervisor.I would like to know the difference of performances.
Could anyone help me?
Thank you.
Giuseppe.
Correct Answer by Ganesh Hariharan about 7 years 4 months ago
Hi all,
Thank you.
Giuseppe.
Hi Giuseppe,
Check out the below link on sup 6E and sup 6E lite hope that helps
http://www.cisco.com/en/US/prod/collateral/modules/ps2797/ps9294/product_data_sheet0900aecd806df543_ps4324_Products_Data_Sheet.html
http://www.cisco.com/en/US/prod/collateral/switches/ps5718/ps4324/product_announcements0900aecd806ed5d2.html
If helpful do rate the post
Ganesh.H
Correct Answer by Jon Marshall about 7 years 4 months ago
gpangallo wrote:
Hi all,
Thank you.
Giuseppe.
Giuseppe
Have a look at the attached doc which covers both the 6E and 6E lite.
Jon
Overall Rating: 4.8 (3 ratings)
Correct Answer
Jon Marshall Tue, 02/02/2010 - 09:40
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
gpangallo wrote:
Hi all,
Thank you.
Giuseppe.
Giuseppe
Jon
Correct Answer
Ganesh Hariharan Tue, 02/02/2010 - 23:33
  • Purple, 4500 points or more
  • Community Spotlight Award,
    Member's Choice, February 2016
Hi all,
Thank you.
Giuseppe.
Hi Giuseppe,
Ganesh.H
