Catalyst 6509 FSM or ASA is better
Feb 2nd, 2010
  • Bronze, 100 points or more
Dears ,
I'm in a confusion that what to choose from the below 2 when implementing a small data centre
Option 1 : Cisco 6509( WS-C6509 with Sup 720-3B)  + FWSM (WS-C6513-FWM-K9)
Option 2 : WS-C6509 and ASA
My requirement is to protect from outside attacks only ..Also what are the failover options available with FWSM ?
I need only certain VLANs to be passed thru FWSM .
Another Question is regarding HSRP , i have two 6509 switches both with 7203b ,but interfaces are different .Whether i Can run HSRP on this ? Whether it need to be the same exact hardware ? .Whether I can put FWSM in one switch only for now or is it needed to put in both switches
Overall Rating: 4 (1 ratings)
Giuseppe Larosa Tue, 02/02/2010 - 11:22
  • Hall of Fame,
    Founding Member
Hello Haris,
FWSM:
can be used in multicontext, contexts can be routed or transparent.
FWSM failover option is to have one FWSM on chassis 1 and second FWSM on chassis 2.
the two chassis can be connected by a L2 trunk, you can have one vlan used for failover and one vlan used for stateful exactly as with an ASA pair.
this is possible, only vlans specified in firewall vlan-group on C6500 supervisor are passed to the FWSM.
We use this setup in several server farms with good results.
FWSM can process 3 Gbps of traffic.
FWSMs cannot act as VPN terminator as an ASA
The ASA performance depends from the model. ASA 5580-40 outperforms FWSM but this is not true for other models
Hope to help
Giuseppe
