02-02-2010 04:12 PM - edited 03-11-2019 10:04 AM
Hello everyone,
I am configuring a PIX 501 for a small office situation, and have a server internally that is providing web-based services on two separate ports. What I want to do is map a public IP for each internal service on the same server.
The server is providing web services on ports 80 and 86, and I have configured the static nat as follows:
static (inside,outside) tcp 1.2.3.4 www 192.168.0.2 www netmask 255.255.255.255 0 0
static (inside,outside) tcp 1.2.3.5 www 192.168.0.2 86 netmask 255.255.255.255 0 0
I also have my ACLs configured to allow traffic on port 80 to those two external IPs. When I look at the log, I see an error about "Deny inbound (no xlate)" for the second entry.
I'm sure that I'm just missing something simple, but for the life of me can't see it. Any help would be appreciated!
Sean
Solved! Go to Solution.
02-03-2010 01:11 PM
Sean,
static (inside,outside) tcp a.b.c.x www 192.168.41.10 www netmask 255.255.255.255 0 0
static (inside,outside) tcp a.b.c.y www 192.168.41.10 8501 netmask 255.255.255.255 0 0
and log:
302013: Built inbound TCP connection 590854 for outside:
02-02-2010 05:20 PM
I do not see anything wrong with the configuration. It appears correct.
Are you seeing these messages?
http://www.cisco.com/en/US/docs/security/pix/pix63/system/message/pixemsgs.html#wp1052137
Pls. copy and paste the exact message. You can make changes to the IP address if you like to match the static pat lines above but, pls. leave the port numbers in tact.
-KS
02-03-2010 10:37 AM
Interesting. I am now getting this message in the log:
305011: Built static TCP translation from inside:192.168.41.10/8501 to outside:a.b.c.d/80
302013: Built inbound TCP connection 589110 for outside:
And I see the hitcount for the permit ACLs incrementing. Yet I cannot actually hit the page, I get timed out. And then I see this:
02-03-2010 10:55 AM
302014: Teardown TCP connection 589117 for outside:
The above logs don't match these IPs in the statics.
-KS
02-03-2010 12:57 PM
You're right, sorry. I edited my paste to hide the IPs on the first one, and wasn't consistent. Here is current:
and log:
02-03-2010 01:11 PM
Sean,
and log:
02-03-2010 02:01 PM
I just tested it on another system on the network, and it failed. Turns out my firewall config was correct, the app developer neglected to open up Windows firewall for the special ports he was utilizing. I went in and opened them, and everything is talking properly.
Thanks for the help, it is much appreciated!
-Sean
02-03-2010 02:06 PM
This happens all the time. No worries. The syn timeout syslog gave it away. Logs are our best friend.
Got to remember that.
-KS
