How to capture traffic on ME3400?
vanjaburic
In my lab I have a non Cisco gateway (Zyxel VSG-1200) with Cisco ME3400 connected to its LAN port and then I have a PC off of ME3400. I am having issues with VLAN's and I'm trying to see why VLAN's won't work with that specific gateway. VLAN's work fine when I use different vendor (such as Cisco and other ones) Is there any way to capture traffic between GTW and ME3400 to see what is going on? I'm having a feeling that VSG is not tagging packets back into the LAN.
Very simple setup
VSG-1200--> ME3400-->PC
Thanks in advance
Ganesh Hariharan
Very simple setup
Thanks in advance
Yes you can configure span session in ME3400 and make one pc with wireshark or ethereal to analyse the traffic which are flowing across the ME3400.
Check out the below link hope that clear out your query !!
http://www.cisco.com/en/US/docs/switches/metro/me3400/software/release/12.2_46_se/configuration/guide/swspan.html
If helpful do rate the post
Ganesh.H
