RME compliance issue - Check for presence of cmd "OR" cmd
Answered Question
Feb 2nd, 2010
It does not appear to me that I can do "OR" logic when checking commands on an interface, for example this is what I want to accomplish:
IF switchport mode access
then IF this command exist "dot1x port-control" OR this command exit "switchport port-security"
do nothing,
Else
Display the Interface Name
I best I have been able to do, is to check for the presense of both commands and a success will display one command per interface in the report and displaying both commands per interface means a failure.
I am running RME 4.1.1
Correct Answer by Joe Clarke about 7 years 2 months ago
You should be able to do something like this to assert the command exists:
+ [#(dot1x port-control|switchport port-security).*#]
Overall Rating: 5 (1 ratings)
Correct Answer
Joe Clarke Tue, 02/02/2010 - 22:33
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
charlie-hall Wed, 02/03/2010 - 14:30
I keep thinking of the "|" pipe in IOS.
That was it though.
I used "!Vlan", so we will check all interfaces except Vlan Interfaces.
I am able to run this on all switches in a subnet, and it works great.
Name:
Name: CheckForDot1X SubMode: No isPrerequisite: No
Ordered : No Prerequisite-Commandset : AccessPortCmdSet Parent: AccessPortCmdSet
AccessPortCmdSet SubMode: Yes isPrerequisite: Yes
Ordered : No Prerequisite-Commandset : none Parent: none
interface [#!Vlan.*#]
+ switchport mode access
thanks!
