VPN Concentrator restriction for internet browsing
Feb 2nd, 2010
I have a question regarding VPN concentrator.
We have configured VPN concentrator with 3005.
User coonect to VPN concentrator from internet to access internal resources.
But there is no restriction for accessing internet when the client conncet via VPN and the traffic is not routed through proxy and hence the internet is open.
However internal user has restriction on the access.
Plz let me know can the access be restricted for the VPN user connecting from internet and policy can be implemented for the URL using internal proxy.
Appreciate if someone can share any document related to this configuration.
Farrukh Haroon Sun, 02/07/2010 - 09:33
  • Red, 2250 points or more
Are you talking about split-tunneling?
You may configure it as per the following:
http://www.cisco.com/en/US/products/hw/vpndevc/ps2284/products_configuration_example09186a00806f34fa.shtml
If you want to ensure that VPN clients cannot access the internet once connected to the VPN (the opposite of split tunnelling), check the 'Tunnel Everything' option in the 'Client Config' Properties. This is mentioned in Step 7 of the link.
Please rate if helpful.
Farrukh
