ASA blocks Traffic non-SIP over SIP port 5060 (TCP) ?
Feb 3rd, 2010
Hi all,
we experience this issue in our network:
a test probe is running ftp requests to a server in order to measure performance between two point of the network.
The ftp uses port TCP:5060 that is a well known port for SIP. The easy conclusion that it is a non sense and that this ftp test should change its connection port is not enough for some people, it is mandatory to make this test work with this configuration. We are trying to understand where should this dirty connection be aborted, the first security device is ASA. ASA has SIP inspection enabled and, as I understood, it considers UDP/TCP:5060 by default (even if in most cases SIP runs over UDP).. is it possible that this inspection block FTP traffic over SIP port? We would maintain SIP inspection active while enabling this FTP traffic: I found the SIP inspection parameter 'traffic-non-sip', could it help with our issue?
An additional information is that ftp client generates SYN but it doesn't receive any SYN ACK: if something blocks, it blocks from the very beginning of the connection.
Thanks a lot
CSCO10235163 Wed, 02/10/2010 - 03:18
by disabling SIP inspection we make FTP connection on port 5060 work, but this is not what we desire: if we disabled SIP inspection, SIP connections wouldn't work anymore and we see such connections passing through our network.
Just to update what I wrote, by doing 'sh run all' I realized that non-sip traffic on sip port is enabled by default by ASA:
policy-map type inspect sip _default_sip_map
description Default SIP policymap
  no ip-address-privacy
  no rtp-conformance
but it seems not to be enough.
Farrukh Haroon Wed, 02/10/2010 - 04:12
That command should do it (its enabled by default). I suspect you are hitting a bug.
I would recommend to open a TAC Case for this (if chaning the FTP port is not an option). There have been numerous bugs on ASA OS related to SIP inspection.
lusandi Thu, 07/14/2011 - 09:09
Did the problem got fixed?
Luis Sandi
P.S Please mark this question as answered if it has been resolved. Do rate helpful posts.
