Management VLAN
Feb 3rd, 2010
Hi Netpro
I got cisco 3550 as backbone Switch ; edge switches connects to 3550 on Fiber
In all we got 5 switches and would increase more shortly, I want to have all switches on management vlan
I did the following but doesnt work
[3550]
Vlan 1
description users
Vlan 2
description managment vlan
ip address 192.168.100.1 255.255.255.0
int gi0/0
switchport trunk encap dot1q
switchport mode trunk
description connected to SW1
SW1 - 2960
int gi0/0
int vlan2
ip address 192.168.100.2 255.255.255.0
ip default-gateway 192.168.100.1
On SW1 with VLAN 1 ip address 192.168.1.100/24 is working ok
M i missing any more config to move all switches to managment VLAN
Jon Marshall Wed, 02/03/2010 - 02:05
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
tomfree_leo wrote:
Hi Netpro
[3550]
Vlan 1
description users
Vlan 2
int gi0/0
SW1 - 2960
int gi0/0
int vlan2
Tom
No that should do it.
Can you post -
1) "sh ip int brief" from bith switches
2) "sh vlan" from both switches
3) "sh int trunk" from both switches
Jonj
tomfree_leo Wed, 02/03/2010 - 02:16
I see VLAN2 cannot be seen on 2960
its a server and client setup, i feel need to shut and no shut the trunk to get vlan database updated.
Any cisco document with recommendation on configuring Management VLAN
tomfree_leo Wed, 02/03/2010 - 02:23
Can someone help to understand what is native VLAN Vs Managment VLAN
Jon Marshall Wed, 02/03/2010 - 02:30
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
Tom
Couple of things.
Yes you need vlan 2 in the output of "sh vlan" on the 2960. Check the revision numbers on the VTP server and client.
Native vlan is simply the vlan that is untagged on a trunk link. The native vlan should not be the management vlan and it should not be a vlan with any ports allocated to it. The native vlan doesn't need a L3 interface either.
Jon
Ganesh Hariharan Wed, 02/03/2010 - 03:28
  • Purple, 4500 points or more
  • Community Spotlight Award,
    Member's Choice, February 2016
A native vlan is the untagged vlan on an 802.1q trunked switchport.Basically if a switch receives untagged frames on a trunkport, they are assumed to be part of the vlan that are designated on the switchport as the native vlan.When the switch on the other side of the trunk receives a frame that does not have an 802.1Q header, the receiving switch knows that the frame is part of the native VLAN.
Hope to help
Ganesh.H
Robert Juric Wed, 02/03/2010 - 06:11
The management VLAN is simply a VLAN that is configured with a L3 interface and is used for to manage the switch via telnet/ssh. Best practices recommend seperating your management traffic from the standard user/data traffic. For my company however, adding and having to track another subnet at each of my branch offices would be a nightmare so we keep management traffic in the data VLAN.
