02-03-2010 02:07 AM - edited 03-03-2019 05:51 AM
Hello Experts,
I have a quick question.
Cisco Reommends to place the sup-1 and 2 in slot 1 and 2 of the chassis, and sup-720 to be places in slot 5 and 6 only.
my question is that why i should place sup-720 in slot 5 and 6 only and not in slot 1 and 2.
will appreciate your quick response.
Many Thanks.
Solved! Go to Solution.
02-04-2010 01:07 AM
Hello Experts,
Many Thanks.
Hi Kaushik,
The Supervisor 720 incorporates a new version of the Policy Feature Card (PFC3A or PFC3B or PFC3BXL) as well as a new Multilayer Switch Feature Card (MSFC3) as well as an integrated 720 Gbps switch fabric. This level of integration increases slot efficiency of high performance and high availability configurations.Because the switch fabric is integrated with the supervisor, the Supervisor Engine 720 must be installed in particular slots.
Chasis Slots for Supervisor Engine 720
6503/6503-E/7603 1 or 2
6506/6506-E/7606 5 or 6
6509/6509-E 5 or 6
6509-NEBS/6509-NEBS-A/OSR-7609 5 or 6
Cisco 7609 5 or 6
6513/7613 7 or 8
Hope to help !!
If helpful do rate
Ganesh.H
02-04-2010 01:07 AM
Hello Experts,
Many Thanks.
Hi Kaushik,
6509/6509-E 5 or 6
Cisco 7609 5 or 6
6513/7613 7 or 8
Hope to help !!
If helpful do rate
Ganesh.H
02-04-2010 10:48 PM
patel.kaushik wrote:
Hello Experts,
Many Thanks.
Just a follow up to Ganesh's post.
It's more than a recommendation, it's an actual requirement. The connection to the switch fabric is provided in slots 5 & 6. Prior to the sup720 there was an module called a Switch Fabric Module (SFM) that could be used with a Sup 2. What this did was to provide a connection to the switch fabric for linecards that were capable of using the switch fabric. Note that not all cards have connections to the switch fabric ie. classic line cards do not.
If you had a sup2 with an SFM the SFM had to go into slots 5 or 6 because that is where the connection the switch fabric is provided. The supervisor 720 has a built in connection to the switch fabric so you don't need an SFM but you do need to use slots 5 & 6 to gain access to the switch fabric.
Jon
02-07-2010 01:54 PM
And it was BUILT that way. Have you seen the connectors of the Sup720 and the slots of the 6500? There's no way you can lock the Sup32/720 in any slots other than what's recommended.
