WAAS - GUI time always shows UTC
Feb 3rd, 2010
Hi All
We have deployed WAAS 4.1.5b and facing issue with time shown on CM dashboard. We have set NTP and correct time-zone across WAEs. show clock shows correct time on CLI for every WAE including CM. However, not showing correctly on CM GUI
Sameer Shah
sameer.shah Tue, 02/09/2010 - 04:51
To modify the dashboard timezone to be the CDM time click on the settings button on the dashboard screen.  Then on each of the tabs change "select timzone" drop-down from UTC to CDM Local Time, once all tabs have been modified click submit.
This change is only set in cookies, and if you logoff from the session, relogin takes you back to UTC.
Anyway we had opened a TAC case, and its being informed to take this with local Cisco team for PER (Product Enhancement Request)
Thanks for all your support
Patrick Moubarak Mon, 03/01/2010 - 13:48
Thanks for the information, I've been having the same issue, hope this will be implemented in 4.2 release...
