Call transfer problem with cisco voip gateway
Answered Question
Feb 3rd, 2010
In my environement, i have CCM 7.0 and 2 gatways h323 3825 and 2811 (all within same Vlan). the 2 gateways are configured the same way but the call transfer works fine with the 3825 gateway but it does not with the 2811 one.
any ideas?
Correct Answer by markbatts about 6 years 8 months ago
Please rate succesful answers
Overall Rating: 5 (2 ratings)
Criss Sawyer Wed, 02/03/2010 - 09:41
thx you for your reply
I check MTP on both gateways, it worked.
the weird thing is that the transfer worked fine with the 3825 gateway without checking this parameter.
