Wlan number
Answered Question
Feb 3rd, 2010
Hello everyone,
I have a Cisco Wireless Lan Controller in version 4.2.176.0, and AP's Cisco AP1010 .
I created 5 WLANs for different services in my corporate network.
I need to create more 3 WLANs for other services, and i am in doubt about the ability of the controller and Ap's to support this load.
There any best practices or some maximum number of WLANs by AP or Controller?
Thanks.
Rafael
Correct Answer by George Stefanick about 7 years 2 months ago
Good question....
Each SSID you add to your WLAN you use medium for managment frames. No big deal right?
When you only have 1 or 2 APs no bid deal. But when you have 10+ access points that your client can see and you have lower data rates enabled you will have higher channel utilization.
Do this ... take 1 AP put 1 ssid and then add another and another ... Run an analyzer and check out your utilization. I've had customers who have 40%+ channel untilization with no  traffic, just managment frames.
I try to keep my SSIDs to 5 and disable the lower data rates.
Overall Rating: 5 (2 ratings)
Leo Laohoo Wed, 02/03/2010 - 13:50
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 LAN, Wireless
You can configure up to 512 SSIDs but only 24 will be "work" ... so to speak.
Correct Answer
George Stefanick Wed, 02/03/2010 - 18:54
  • Purple, 4500 points or more
  • Community Spotlight Award,
    Best Publication, October 2015
Good question....
Rafael Mendes Thu, 02/04/2010 - 04:03
Well...
Thanks for response.
So, i have 400 AP's and 4 controllers, into the my network.
My question is, AP's have a maximum number of SSID's? I can create more 3 wlans/ssids?
Second answer above, I have 512 SSIDs configured, only 24 more will radiate the signal to customers, is it?
Leo Laohoo Thu, 02/04/2010 - 14:09
  • Hall of Fame,
    2017 LAN, Wireless
That's what I said in my first post.
George Stefanick Thu, 02/04/2010 - 18:43
Wait a minute he said 1010 access points. If memory serves me right these dusty puppys can only do 8 ssids ... Right Leo !?
George Stefanick Thu, 02/04/2010 - 18:47
found it ,... 16 per
Note:
Cisco Aironet 1000 Series APs support 16 BSSIDs per radio and 16 WLANs
per AP.
Leo Laohoo Thu, 02/04/2010 - 19:13
  • Hall of Fame,
    2017 LAN, Wireless
You got that one right George.
