LMS & HUM integration
Feb 3rd, 2010
I have LMS 3.2 1500 devices LIC & HUM 1.2 1000 Devices LIC.
Can I install them on the same physical server ?
If I can, what is the server requirements ?, I saw at the LMS 3.2 installation only HUM 300 + LMS 1500 server requirements.
Appreciate your help,
Sven Hruza Wed, 02/03/2010 - 13:29
  • Bronze, 100 points or more
In the user guide for HUM there is a table 1.1 which describes that a HUM lic for 1000 devices is not supported in a bundle with LMS 3.1.
You have to install it on its own server wogether with Common Services (as slave) and portal.
http://www.cisco.com/en/US/docs/net_mgmt/ciscoworks_health_and_utilization_monitor/1.1/user/guide/HUMovrvw.html
For the server requirements you have to check the documentation of LMS 3.1
http://www.cisco.com/en/US/docs/net_mgmt/ciscoworks_lan_management_solution/3.1/install/guide/prereq.html
Sven
