02-03-2010 07:07 AM - edited 03-04-2019 07:23 AM
I am configuring Cisco 2611 router for Internet connection with VWIC 2MFT G703 interface card. router has 2 fastethernet ports and 2 E1 ports ( VWIC 2MFT g703 card). Service Provider has provided the G703 unframed signal and encapsulation is ppp. I configured E0/0 channel-group 0 is unframed and clock source is line and configured WAN IP to s0/1:0 and LAN IP (public ip) to FastEthernet 0/0. I am able to ping gateway IP. But not able to ping other public IPs. Please suggest me
Building configuration...
Current configuration : 1109 bytes
version 12.2
hostname c2611
logging queue-limit 100
enable secret 5 $1$sVCa$kuEmS0y0jt7Qv5R1.QdU5.
enable password
ip subnet-zero
no ip routing
ip name-server 4.2.2.2
no voice hpi capture buffer
no voice hpi capture destination
mta receive maximum-recipients 0
controller E1 0/1
channel-group 0 unframed
controller E1 0/0
interface FastEthernet0/0
ip address x.x.x.x 255.255.255.224
no ip route-cache
no ip mroute-cache
duplex auto
speed auto
interface Serial0/0:1
ip address x.x.x.x 255.255.255.252
encapsulation ppp
interface FastEthernet0/1
no ip address
no ip route-cache
no ip mroute-cache
shutdown
duplex auto
speed auto
interface Serial0/1:1
no ip address
ip http server
ip classless
call rsvp-sync
mgcp profile default
dial-peer cor custom
line con 0
line aux 0
line vty 0 4
password
login
02-03-2010 07:20 AM
Hello Saisrinivas,
You will need a default route toward your service providers IP address, so you can get to the outside world.
Example:
ip route 0.0.0.0 0.0.0.0 192.168.1.1
Reza
02-03-2010 07:58 AM
Hi Reza,
I did the IP route 0.0.0.0 0.0.0.0 x.x.x.x. So that I am able to ping my service provider address only. but not to any other public IPs. My service provider is not able to ping my router IP.
02-03-2010 08:06 AM
Hello Saisrinivas,
Between you and your service provide is a direct serial link and the same way you can ping them, they should be able to ping you.
Verify to make sure they are pinging the right IP address and also you assigned the correct IP on your side. Also make sure the encapsulation is correct on both sides.
Reza
02-04-2010 02:27 AM
Hi Reza,
Thank you for your response.
I have checked with my service provider and encapsulation and IPs are correct. They are saying that it is with my configuration problem.
Can you suggest me for the configaration.
