Issue with Inline Power
Answered Question
Feb 3rd, 2010
Hello friends, I've been configuring a NME-16ES-1G-P, and it's needed to shutdown the internal logical interface, but when I do that an error is shown "Shuting down Internal GE interface GigabitEthernet1/0 may render inline power for EtherSwitch Service Module not working properly", what issues can It bring to my network performance, or what problems can I have on my network?
Thanks in advance
Correct Answer by Reza Sharifi about 6 years 11 months ago
Hello Jonas,
Be careful with this command, If you shut the internal interface down, it will bring down the local vlan interfaces also and effect your neighbor adjacency.
Switch(config-if)#sh
%Warning:Internal interface GigabitEthernet1/0/2 is shutdown. System will not deliver power any more if new IP phones are connected
Reza
Overall Rating: 5 (2 ratings)
Correct Answer
Reza Sharifi Wed, 02/03/2010 - 08:52
Hello Jonas,
Reza
Leo Laohoo Wed, 02/03/2010 - 13:13
When you do this it means that the command "might" disable the module completely.  But in reality, if you disable the logical interface, the module powers down.
Related Content
