Wireless Wyse Terminals
Feb 3rd, 2010
I have a WLC on code 6.0.182.0.  There are some wireless Wyse Thin clients that connect to the network fine but then there are issues with the session locking up and such.  There are errors I am seeing that are associated with "RSN IE"  "EAPOL Invalid" etc. etc.  These do work but there are itermittent issues with them.  My notebook works great and I would then if the PSK or something was wrong then these clients would never work at all.
I went into the troubleshoot function in WCS and I was able to get this:
Time :02/03/2010 08:42:59 EST Severity :INFO Controller IP :192.168.1.1 Message :Controller association request message received.
Time :02/03/2010 08:42:59 EST Severity :INFO Controller IP :192.168.1.1 Message :Association request received from a client has an invalid RSN IE.(One reason could be mismatch in WPA2 algorithm).
Time :02/03/2010 08:42:59 EST Severity :INFO Controller IP :192.168.1.1 Message :Received reassociation request from client.
Time :02/03/2010 08:42:59 EST Severity :INFO Controller IP :192.168.1.1 Message :The wlan to which client is connecting requires 802 1x authentication.
Time :02/03/2010 08:42:59 EST Severity :INFO Controller IP :192.168.1.1 Message :Client moved to associated state successfully.
Time :02/03/2010 08:42:59 EST Severity :ERROR Controller IP :192.168.1.1 Message :802.1x authentication message received, static dynamic wep supported.
Time :02/03/2010 08:42:59 EST Severity :INFO Controller IP :192.168.1.1 Message :802.1x authentication was completed successfully.
Time :02/03/2010 08:42:59 EST Severity :INFO Controller IP :192.168.1.1 Message :Client has got IP address, no L3 authentication required.
Time :02/03/2010 08:42:59 EST Severity :INFO Controller IP :192.168.1.1 Message :Radius packet received. Accounting-Response received from RADIUS server 192.168.4.1, receiveId = 0
Time :02/03/2010 08:42:59 EST Severity :INFO Controller IP :192.168.1.1 Message :Dhcp Information. transmitting DHCP DISCOVER (1)
Time :02/03/2010 08:42:59 EST Severity :INFO Controller IP :192.168.1.1 Message :Dhcp Information. op: BOOTREQUEST, htype: Ethernet, hlen: 6, hops: 1
Time :02/03/2010 08:42:59 EST Severity :INFO Controller IP :192.168.1.1 Message :Dhcp Information. xid: 0x25d34943 (634603843), secs: 8, flags: 0
Time :02/03/2010 08:42:59 EST Severity :INFO Controller IP :192.168.1.1 Message :Dhcp Information. chaddr: 00:12:7b:4a:d3:25
Time :02/03/2010 08:42:59 EST Severity :INFO Controller IP :192.168.1.1 Message :Dhcp Information. ciaddr: 0.0.0.0, yiaddr: 0.0.0.0
Time :02/03/2010 08:42:59 EST Severity :INFO Controller IP :192.168.1.1 Message :Dhcp Information. siaddr: 0.0.0.0, giaddr: 10.30.207.242
Time :02/03/2010 08:42:59 EST Severity :INFO Controller IP :192.168.1.1 Message :Dhcp Information. transmitting DHCP OFFER (2)
Time :02/03/2010 08:42:59 EST Severity :INFO Controller IP :192.168.1.1 Message :Dhcp Information. op: BOOTREPLY, htype: Ethernet, hlen: 6, hops: 0
Time :02/03/2010 08:42:59 EST Severity :INFO Controller IP :192.168.1.1 Message :Dhcp Information. xid: 0x25d34943 (634603843), secs: 0, flags: 0
Time :02/03/2010 08:42:59 EST Severity :INFO Controller IP :192.168.1.1 Message :Dhcp Information. ciaddr: 0.0.0.0, yiaddr: 10.30.200.97
Time :02/03/2010 08:42:59 EST Severity :INFO Controller IP :192.168.1.1 Message :Dhcp Information. siaddr: 0.0.0.0, giaddr: 0.0.0.0
Time :02/03/2010 08:42:59 EST Severity :INFO Controller IP :192.168.1.1 Message :Dhcp Information. server id: 1.1.1.1 rcvd server id: 10.30.12.107
Time :02/03/2010 08:42:59 EST Severity :INFO Controller IP :192.168.1.1 Message :Dhcp Information. transmitting DHCP REQUEST (3)
Time :02/03/2010 08:42:59 EST Severity :INFO Controller IP :192.168.1.1 Message :Dhcp Information. requested ip: 10.30.200.97
Time :02/03/2010 08:42:59 EST Severity :INFO Controller IP :192.168.1.1 Message :Dhcp Information. server id: 10.30.12.107 rcvd server id: 1.1.1.1
Time :02/03/2010 08:42:59 EST Severity :INFO Controller IP :192.168.1.1 Message :Dhcp Information. transmitting DHCP ACK (5)
Time :02/03/2010 08:48:05 EST Severity :ERROR Controller IP :192.168.1.1 Message :EAPOL-key is retransmitted.
Time :02/03/2010 08:48:06 EST Severity :ERROR Controller IP :192.168.1.1 Message :EAPOL-key is retransmitted.
Time :02/03/2010 08:48:06 EST Severity :ERROR Controller IP :192.168.1.1 Message :De-authentication sent to client. slot 0 (claller 1x_ptsm.c:467)
Time :02/03/2010 08:48:06 EST Severity :ERROR Controller IP :192.168.1.1 Message :EAPOL-key is invalid, scheduling client for deletion.
Time :02/03/2010 08:48:07 EST Severity :INFO Controller IP :192.168.1.1 Message :Controller association request message received.
Time :02/03/2010 08:48:07 EST Severity :INFO Controller IP :192.168.1.1 Message :Association request received from a client has an invalid RSN IE.(One reason could be mismatch in WPA2 algorithm).
Time :02/03/2010 08:48:07 EST Severity :INFO Controller IP :192.168.1.1 Message :Received reassociation request from client.
Time :02/03/2010 08:48:07 EST Severity :INFO Controller IP :192.168.1.1 Message :The wlan to which client is connecting requires 802 1x authentication.
Time :02/03/2010 08:48:07 EST Severity :INFO Controller IP :192.168.1.1 Message :Client moved to associated state successfully.
Time :02/03/2010 08:48:07 EST Severity :ERROR Controller IP :192.168.1.1 Message :802.1x authentication message received, static dynamic wep supported.
Time :02/03/2010 08:48:08 EST Severity :ERROR Controller IP :192.168.1.1 Message :EAPOL-key is retransmitted.
Time :02/03/2010 08:48:08 EST Severity :INFO Controller IP :192.168.1.1 Message :802.1x authentication was completed successfully.
Time :02/03/2010 08:48:08 EST Severity :INFO Controller IP :192.168.1.1 Message :Client has got IP address, no L3 authentication required.
Time :02/03/2010 08:48:08 EST Severity :INFO Controller IP :192.168.1.1 Message :Radius packet received. Accounting-Response received from RADIUS server 192.168.4.1, receiveId = 0
George Stefanick Wed, 02/03/2010 - 11:08
  • Purple, 4500 points or more
  • Community Spotlight Award,
    Best Publication, October 2015
Can you create an open test ssid with no security and see if these have trouble connecting...
