AP500 connect external outdoor antenna
Answered Question
Feb 3rd, 2010
is it posible to connect an outdoor antenna to the AP540?
And if Yes, which ones will fit?
Many Thanks in advance.
@lex
Correct Answer by Glenn Quesenberry about 7 years 2 months ago
If you are referring to the AP541N, the antennas are detachable, however we do not specifiy/recommend any external or outdoor antennas for this unit.
Best Regards,
Glenn
Overall Rating: 5 (1 ratings)
Correct Answer
Glenn Quesenberry Sun, 02/07/2010 - 17:31
  • Cisco Employee,
Best Regards,
Glenn
