CAR CDR Analysis and Reporting
Feb 3rd, 2010
I am running CUCM 7.1.2a
On trying to run certain CAR reports namely any device reports/ Route plan - Route Pattern reports
I get the error
Error Code
Error Description
10011
System Error. Contact System Administrator.
All other reports seem to work.I also see that other people have had this problem on other versions of  CUCM. Any ideas anyone
Overall Rating: 5 (1 ratings)
Rob Huffman Thu, 02/04/2010 - 05:26
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Luis,
Nice find here (+5 points for this good work)
Cheers!
Rob
p.horwood Thu, 02/04/2010 - 05:31
I'll give it a try today. As Rob says a great spot
Paul Horwood
p.horwood Thu, 02/04/2010 - 06:57
Sadly I tried all 4 solutions and none of them worked
Paul Horwood
Rob Huffman Thu, 02/04/2010 - 07:32
  • Hall of Fame,
    Founding Member
Hey Paul,
It looks like this bug
CSCsz46571 Bug Details Bug #16 of 72 | < Previous | Next >
CDR: PDF Route Pattern utilization report fails with 10011 System Error
Symptom:
Unable to generate PDF reports for Device Reports -> Route Plan -> Route Pattern/Hunt Pilot Utilization. The following error message is displayed:
"10011  System Error. Contact System Administrator."
Workaround:
Instead of generating a PDF report, generate a CSV report
Status
Fixed
Severity
3 - moderate
Last Modified
In Last Year
Product
Cisco Unified Communications Manager (CallManager)
Technology
1st Found-In
7.0(2)
Fixed-In
7.1(2.39000.38)
7.0(2.21017.1)
7.1(2.21001.1)
7.1(3.10000.11)
Hope this helps!
Rob
lusandi Thu, 02/04/2010 - 08:35
  • Bronze, 100 points or more
I would like to confirm whit you if you can create the csv files?
or you just can not create the reports?
I will be waiting for the information.
p.horwood Thu, 02/04/2010 - 09:22
Luis,
User Reports, System Reports and searching the CDR all work and that includes csv and pdf. My problem is I cannot get the Device reports to work namely Route List/Group Route Pattern Utilization
Paul
0131 448 4988
