Removing Drop Rules
Feb 3rd, 2010
I am very new to configuring our MARS. I recently added a drop rule by mistake. I've tried marking it inactive, but it's still showing as a false positive. I would like to completely delete the rule all together if that is possible.
Thanks!
RicheeJJJ_2 Wed, 02/03/2010 - 16:49
Yeah, when looking at the drop rules page, the delete button is on the top right and bottom right of the page.
kerry.kielty Thu, 02/04/2010 - 11:08
Delete is not an option. I have the following buttons to choose from:
Edit
Change Status (which will only change it to inactive)
Duplicate
Add
I have included a word doc with the screen shots.
Thank you
Farrukh Haroon Sun, 02/07/2010 - 08:11
I don't know what do you mean by 'its still showing as false positive'? Can you please clarify.
Drop rules cannot be deleted in MARS. However you can make them inactive (which will functionally have the same effect). Just make sure you hit the 'Activate' button on the top right after marking the change.
Please rate if you find the post helpful.
Farrukh
