PAP one-way authentication failing..
hi,
I connected two routers R1 and R2 via serial link to configure ppp pap uni-directional authentication but its not working. following is the config
R1:
username PAPU password cisco
interface Serial0/0
ip address 10.1.1.1 255.255.255.0
encapsulation ppp
ppp authentication pap
end
R2:
interface Serial0/0
ip address 10.1.1.2 255.255.255.0
encapsulation ppp
ppp authentication pap callin
ppp pap sent-username PAPU password 0 cisco
end
and it is showing the following msg when i run debug pap authenication on both routers
*Mar  1 01:04:32.467: Se0/0 PPP: Authorization required
*Mar  1 01:04:32.675: Se0/0 PPP: Authorization required
R1#
*Mar  1 01:04:34.671: Se0/0 PPP: Authorization required
R1#u
*Mar  1 01:04:36.619: Se0/0 PPP: Authorization required
Did i configure some thing wrong..
nareh
Edison Ortiz Wed, 02/03/2010 - 13:42
  • Hall of Fame,
    Founding Member
Remove
From R2
You are making R2 an authentication server as well while per your output and requirements, R2 is just the client.
Giuseppe Larosa Wed, 02/03/2010 - 13:43
  • Hall of Fame,
    Founding Member
Hello Nareh,
check if AAA new model is configured on your routers
or if you like post
sh run | inc aaa
Edit:
I think Edison is on spot here
Hope to help
Giuseppe
