Creating Dial 0 to Recept. for 3 different offices in one CUCM
Answered Question
Feb 3rd, 2010
/* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-priority:99; mso-style-qformat:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin-top:0in; mso-para-margin-right:0in; mso-para-margin-bottom:10.0pt; mso-para-margin-left:0in; line-height:115%; mso-pagination:widow-orphan; font-size:11.0pt; font-family:"Calibri","sans-serif"; mso-ascii-font-family:Calibri; mso-ascii-theme-font:minor-latin; mso-hansi-font-family:Calibri; mso-hansi-theme-font:minor-latin; mso-bidi-font-family:"Times New Roman"; mso-bidi-theme-font:minor-bidi;}
We have CUCM 6.1.1 that is being used for 3 different offices.  Each Office has each own reception.  I just got a request so when the users dial 0, it will go to the respective office.  Our vendor that installed the CUCM has created for 2 of the offices.  I need another one since we just add this office joining the CUCM.  I looked at the CUCM configuration that we have for the 2 offices that already setup and come up with this, please let me know if I do it wrong or what should have it done.  Thank you
1.     1.  Create a new “Calling Search Space” for this new office, example: Texas_Internal
2.      2. Create a new “Partition”, example: Texas_Local
3.      3. Create a new “Device Pool”, example: Texas_Phones
a.       CSS for this device = Texas_Internal
4.      4. Create a new “Translation Patterns”
a.       Translation Pattern = 0
b.      Partition = Texas_Local
c.       Calling Search Space = Texas_Local
d.      Called Party Transform Mask = 6000 (reception Extension number for this new office)
5.      5. Assigning a new phone with
a.       Device Pool = Texas_Phones
Is there anything that I miss or is there any other way to do this?
Thank you for your help
sienz
Correct Answer by CHRIS CHARLEBOIS about 7 years 3 months ago
I would recommend, for your own sanity and for clearer documentation, to include what kind of thing it is to the name.  For example, every partition I create ends in _PT and every calling search space ends with _CSS.  Because Texas_Local_PT is not the same as Texas_Local_CSS, and there is not a 1-to-1 relationship, either.  Let me explain.
Phones that are assigned the Texas_Internal_CSS should only be able to dial numbers in the Texas_Internal_PT.  Therefore, only the Texas_Internal_PT should be listed within the Texas_Internal_CSS.
Phones that are assigned the Texas_Local_CSS should only be able to dial numbers in the Texas_Internal_PT and the Texas_Local_PT.  Therefore, both partitions should be listed in the Texas_Local_CSS.
Phones that are in the Texas_LD_CSS should be able to dial numbers in the Texas_Internal_PT, the Texas_Local_PT and the Texas_LD_PT.  So all three partitions should be in the Texas_LD_CSS.
The key is that Partitions help you define logical groups of extensions, route patterns, and translations patterns that can be dialed.  Calling Search Spaces grant permission to a device to call those groups.
Hope this helps,
Chris
Overall Rating: 5 (1 ratings)
CHRIS CHARLEBOIS Wed, 02/03/2010 - 10:56
  • Silver, 250 points or more
A couple things...  Typically I create the CSS after I create the Partition because you need to specify the Partition in the CSS.  Do you have Texas_Internal partition listed in the Texas_Internal CSS?
Second, you looks like you are saying that you specified the CSS in the Device Pool.  The Device CSS cannot be set inside the Device Pool.  There is a CSS option there, but it is only for the Auto-registration feature or Device Mobility.  The CSS needs to be configured on the Device itself and/or on the Directory Number.
Check those two things and let us know...
Chris
sienz.sienz Fri, 02/05/2010 - 10:43
Hi Chris, Thank you for your response
I have completed about 75% i think.
I have to created Texas_Internal, Texas_local, Texas_longdistance, Texas_International.
fyi, The Texas_International contains Texas_Internal, Texas_local, Texas_longdistance, internal and VMport
In our translation pattern 0 for this texas office,
  • Translation Pattern = 0
  • Partition = Texas_Local
  • Calling Search Space = texas_Local
  • Called Party Transform Mask = 6000
I assigned the phone CSS to Texas_International so it is dialing the Texas 0 translation pattern when this phone dial 0 and it is working.
My problem,
After creating Texas_Internal, Texas_local, Texas_longdistance, Texas_International,
How can i tell the system
Texas_local can dial local number
Texas_longdistance can dial long distance number
Texas_International can dial international number
It is currently only can dial internal number.
sienz
Correct Answer
CHRIS CHARLEBOIS Fri, 02/05/2010 - 10:59
Hope this helps,
Chris
sienz.sienz Fri, 02/05/2010 - 14:47
Got it Chris.
Thanks much.
I just read about the partition and CSS and i got a better understanding now.  Everything was created by the vendor.  It was created a confusion for me when i try to check and match the configuration since it is using the same name.
sienz
