CDR Reporting software for CUCM 7.X
Feb 3rd, 2010
Dear All,
Please can anyone suggest or recommend a CDR reporting software
for a small environment (less then 100 endpoints) running CUCM 7.X.
Many thanks in advance.
Zahid
gonzalezel Mon, 05/12/2014 - 11:48
Hi- Do you know if with the Varify system if you can give access to different departments to have them run their own reports.
tinasmith510 Mon, 05/12/2014 - 11:59
Yes, you can. You will be able to give different departments to run their own report or you can schedule and email the report to run automatically.
