Standby ip and Template
Hello All,
Thanks in advance to those who even read this topic and Many thanks to those who will reply. Here is my problem:-
I have to search for devices which do not have standby ip authentication setup. I have tried multiple permutation and combinations to setup a template both basic and advanced to match the standby <group number> ip authentication command in device config. But sadly all devices show as compliant.
Can someone help me with making a template to achieve this?
Many thanks
Joe Clarke Thu, 02/04/2010 - 16:40
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
Do you mean the "standby authentication " command?  It would be helpful to see a current running config to know exactly what you want to match on.  I'd also like to see one of your existing templates to get a better idea what you're trying to do.  In my head, I'm picturing something like:
Submode : interface [#GigabitEthernet.*#]
Body:
+ [#standby 1 authentication (md5|text) .*#]
Joe Clarke Fri, 02/05/2010 - 10:37
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
Well, that will not work as you are not using proper regular expressions.  Try:
Submode : interface [#(Vlan|.*Ethernet).*#]
Body:
+ [#standby \d+ authentication .*#]
Related Content
