spa3102 pstn caller id
Feb 3rd, 2010
I am using spa3102 (lastest firmware) in India with BSNL PSTN connection.
I found that when I receive a call in PSTN, not getting the right caller id information.
Instead its showing my userid defined in PSTN tab for all incoming call.
PSTN Ring Thru Delay is 3 sec
Caller id method is set to DTMF (denmark / Findland+sweden)
any help from members?
juunda Thu, 02/04/2010 - 16:05
This issue has happened before for different countries around the world, originally the device was designed to only show caller ID information on the USA and CANADA, slowly but surely I know they are adding different countries from all over the world in future firmwares, the only information I can share with you is that in  they will eventually incorporate the correct caller ID coding  for foreign countries, for India in particular I wouldn't have any kind of information to share at this time.
