One Lobby Ambassador on multiple WLCs
Feb 4th, 2010
I have wireless network with 2 WLCs and I configured a guest access WLAN with web autentication.
I would like to use a LOCAL authentications with lobby ambassador for guest users.
Is there a way to create a user only once in one WLC?
At the moment I have to connect to each wlc with lobby ambassador privilege and create the same user/pwd on each.
Johnny
Lucien Avramov Thu, 02/04/2010 - 07:50
Then there is no easy way to achieve it.
You would have to reverse engineer SNMP on the WLC, and find out how with SNMP you can create the guest user.
You are much better off with WCS.
scottwilliamson Mon, 02/08/2010 - 06:02
Hi Johnny,
I reckon you only have to create the guest user on the Anchor Controller (that's assuming you have your wireless infrastructure configured that way) as that is the WLC that is doing the authentication.
Hope this helps
Scott
Trending Topics - Security & Network
