Catalyst 6500 named ACL applied to L2 port
Feb 4th, 2010
Hi guys,
  I have Cat6500 with named ACLs matching L4 traffic configured and applied to L2 port. Software is : (s3223_rp-IPBASEK9-M), Version 12.2(18)SXF5.
  I cannot use PACL as it requires a bit higher revision number software I believe.
  The problem I have is that it looks like that ACL can be applied to L2 port but doesn't seem to do anything, I cannot see any hits on ACL entries.
  Anybody can help me out with identifying the cause of it ? I'm pretty sure both named and numbered ACLs can be applied to L2 port.
many thanks in advance.
Ganesh Hariharan Thu, 02/04/2010 - 04:04
  • Purple, 4500 points or more
  • Community Spotlight Award,
    Member's Choice, February 2016
Hi guys,
Cisco IOS Release 12.2(33)SXH and later releases support PACLs.PACLs filter incoming traffic on Layer 2 interfaces, using Layer 3 information, Layer 4 header information, or non-IP Layer 2 information.
Yes it should work can you share the acl configuration which you have applied on switch.
Ganesh.H
mgajew Thu, 02/04/2010 - 04:47
Hi Ganesh,
  ACL is pretty simple :
Extended IP access list test
     5 deny ip any any
int fa1/10
interface FastEthernet1/10
switchport
switchport access vlan 10
switchport mode access
no ip address
ip access-group test in
result is that even with this ACL , all traffic is going through - even there are hits on the following :
switch#  sh tcam int fa1/10 acl in ip
* Global Defaults shared
Entries from Bank 0
Entries from Bank 1
    deny         ip any any (730 matches)
traffic is going NOT within the same subnet.
And as you noticed I cannot apply PACL because of lower soft ver which would probably solve the problem, but don't quite follow why Cat allows applying ACL that it doesn't respect ?
Jon Marshall Thu, 02/04/2010 - 04:58
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
mgajew wrote:
Hi Ganesh,
     5 deny ip any any
int fa1/10
switchport
no ip address
Entries from Bank 0
Entries from Bank 1
I'm not sure this will work. SXF train allows an acl to be applied to a L3 port only ie. there is no mention of it being applied to a L2 port. I suspect it let you do it simply because the code is there for L3 routed ports.
As you say only when you get to SXH does it allow you to apply an acl to a L2 port.
Jon
Jon Marshall Thu, 02/04/2010 - 04:34
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
mgajew wrote:
Hi guys,
When you say you don't see any hits, that is normal for a 6500 because packets are processed in hardware so acl hitcounts are not incremented. If the packet was processed in software then you would indeed see acl hits.
So the more important question is does the acl actually restrict the traffic or not ?
Jon
