Remote Access VPN with PPPOE (DSL) - Dynamic IP
Feb 4th, 2010
Hi all!
I need to configure Remote Access VPN on a router 1751. But this router receives dynamic IP (PPPOE - DSL) of the provider. I know to configure static IP, but do not know for PPPOE dynamic IP.
Attach topology and configuration for Static IP (working).
Appreciatte any help!
pudawat Fri, 02/05/2010 - 11:26
HI JR,
If a remote peer has a dynamic IP address, you can use the hostname as the peer IP address.
Just add the command into the configuration:
#crypto isakmp identity hostname
Make sure that the hostname you are using should be an FQDN
Thanks and Regards,
Pradhuman
