Easy VPN xauth configuration
Feb 4th, 2010
hi,
I have setup an easyvpn between a ASA5510 and a 877 router. Each time the tunnel goes down, i am prompted to enter my username and password See below.
Sending XAuth Request, Please enter the following command:
*Mar  3 18:51:32.919: EZVPN: crypto ipsec client ezvpn xauth
Is it possible to configure the VPN so as it connects automatically and does not prompt you to enter the username and password.
Derek
pudawat Fri, 02/05/2010 - 11:16
Hi Derek,
Assuming that ASA 5510 is EZVPN server and Cisco 877 is EZVPN client
Just add\replace the following commands into the existing configuration:
CLIENT CONFIG:
crypto ipsec client ezvpn tunnel22
  connect manual
  group tunnel22 key 22tunnel
  mode client
  peer 192.0.0.1
  xauth userid mode local(not interactive)
====================OR===================
SERVER CONFIG:
tunnel-group EZVPN general-attributes
 #isakmp ikev1-user-authentication none
Thanks & Regards,
Pradhuman
