ACS 4.2 - How to create a report with the time when user expires
Feb 4th, 2010
I suceeded to see the report with users to group mapings but i also need to knoe the time when the user expires.
How can i see that report?
Jagdeep Gambhir Thu, 02/04/2010 - 09:51
  • Red, 2250 points or more
Unfortunately there is no way to know which user is about to expire.
~JG
Do rate helpful posts
darpotter Mon, 02/08/2010 - 04:43
  • Silver, 250 points or more
Assuming you mean the ACS internal user account expiry..... With extraxi aaa-reports! you can import the ACS user database and run reports on account expiry..in fact you can see all the groups and users plus many other of the attributes set for each. You can build custom reports with sorting, filtering, field renaming, grouping, totalling and calculated fields. Export the results out to CSV, XLS, HTML etc
Please check out http://www.extraxi.com/aaare.htm for more info plus a 60 day free trial.
