Click to call parameters storage (login / password)
Feb 4th, 2010
We have to deploy « Click to call » on several PC, with same parameters for all users (login/password) on all PC.
The aim is to install in admin mode the software, than to copy parameters to all users present on each PC using their own personnal directories.
So, we tried to copy the configuration file clicktocall.xml in the several users personnal directories.
Some parameters are correctly transmited, but the user and password are not.
Is it possible to localize and / or to copy this parameters for all Windows account, or the only solution is to log on with each account present on each PC ?
Thanks in advance for you help.
Philippe
Jose Mendez Thu, 04/07/2011 - 17:18
  • Silver, 250 points or more
In Click to call 8, the following file contains username, password, and server address:
C:\Documents and Settings\[user Name]\Application Data\Cisco\Cisco  Unified Communications\CiscoUnifiedCommunicationsWidgetsEncryptedConfig.xml
