Please Explain UCCX Max Agents / Enhanced Seats Concept
Jonathan Schulenberg Thu, 02/04/2010 - 07:31
  • Cisco Designated VIP,
    2017 IP Telephony
The maximum number shown is the maximum number of seat licenses that your hardware is capable of supporting. In your case, 300 is also the product limitation of CCX.  If you have 110 seats, then you can have up to 110 agents and or supervisors logged in at any one time.
Chris Deren Sat, 02/06/2010 - 07:33
  • Hall of Fame,
    2017 IP Telephony, Contact Center, Unified Communications
Correct, your system can scale up to 300 seats, so if you require more agents you simply procure additional licenses (up to 300) and apply them to the system.
HTH,
Chris
"Does this mean that I can have a maximum of 300 agent accounts set up in the system?"
Not my understanding. You could configure 600 agents as long as no more than 300 are logged in concurrently.
The CAD licence server operates on CONCURRENT SEATS (agents or supervisors) bu I use CAD in UCCE - I defer to the Express experts.
Geoff
Chris Deren Sat, 02/06/2010 - 21:11
  • Hall of Fame,
CAD works pretty much the same in Express as it does in Enterprise.  As to the agent limit again, there is nothing preventing you from defining as many agents as you want built into the application, the 300 limit is what is supported on the platform.  For more details on supported agent count per platform refer to SRND.
Chris
Abdulbaseer Mohammed Sat, 02/06/2010 - 22:30
  • Silver, 250 points or more
Like Chris and Geoff indicated, you can have as many accounts as you like created however the max number of agents that can be logged in at same time is upto 300.  UCCX is designed for small to medium buisness.  You currently have license for 110 your max limit is 300 and that is the limit possible for UCCX.
Even if you like to buy more licenses or install it UCCX will not allow any agents login beyond 300 that is the max.
Good luck.
Baseer.
gbljoba Wed, 02/10/2010 - 08:08
Is it possible to see in real-time how many of the 110 concurrent licences are being used?
Jon
bsugamele1 Thu, 02/11/2010 - 08:25
Yes, in real time reports if you click on Report/Overall Cisco Unified Contact Center stats, it will show you how many Logged in Resources you have. That number represents how many licenses you are using.
Andrew Short Mon, 12/20/2010 - 08:39
Is there a Historical report that will capture the max-agents logged in for a given period of time?
bsugamele1 Fri, 05/13/2011 - 08:21
Sorry, I know this post is 5 months late but....
I don't think so. I have been looking for a historical report that shows the peak number of concurrent agents logged in at any given time, and have not been able to find it. I have been running an agent login/logout summary report and then counting the number of agents. I do this for a few dates throughout the month and it gives me a pretty good idea.
Cisco, if you are reading this....please include a UCCX report that helps us plan for licensing!!
John Powell Thu, 06/16/2011 - 09:32
Yep--trying to find concurrent license counts too.  Makes no sense that a system with concurrent licensing cannot tell you how many concurrent licenses are being utilized at any given time!  I'm surprised this hasn't been corrected yet.
jpsweeney77 Thu, 07/07/2011 - 19:33
  • Bronze, 100 points or more
Alright, I think I can help here. There is a manual way to show all Agents logged into the system through Real Time Reporting in UCCX. However, this does not include Supervisor's who may be logged in as Sups but not Agents so you must keep this in mind. To manually get this same info from the DB, you can run the following SQL at predetermined intervals and offload the results to a separate DB with a DateTime and AgentsLoggedIn column.
Select loggedinagents from RtICDStatistic
If you want to get the TRUE license in use count you will need to go to the CLI (assuming UCCX 8 and above) and run the command 'show uccx cad license usage'.
michaelzhq Thu, 06/06/2013 - 08:45
I know this is an old post, hopefully someone can help me.
When checking the license usage, I see the different results in Real Time Reporting and CLI.
CLI:
admin:show uccx cad license usage
License Report for seat:
        7 of 75 available.
Real Time Reporting:
Logged-in Resources: 62
Why the License Report from CLI shows 6 more license usage than Real Time Reporting? What are these six licenses used for?
