VWIC2-2MFT-G703, cRTP and Multilink
g.petit
I wish to know if it is possible aggregate 2 E1/G703 data link in order to increase bandwidth up to 4 Mbps (2x 2 Mbps) with the card VWIC2-2MFT-G703, by using ppp encapsulation with the multilink feature.
I have read several documents and according to them, I conclude that this setup is possible but I can not test it.
Does somebody can confirm that such setup is possible ?
With the same idea, with 2 cards (VWIC2-2MFT-G703) is it possible to get 8 Mbps (2x 2 Mbps per card) ?
I will use 18xx or 29xx routers.
Next, with this setup, I whish to enable cRTP.
I suppose that I can enable this feature on the Multilink interface with something like that:
interface Mutlilink <group-number>
ip address <address> <mask>
encapsulation ppp
ppp multilink
ip rtp header-compression ...
Does somebody can confirm that cRTP is available with such setup (multilink with VWIC2-2MFT-G703 card) ?
Thanks for your Help.
GP.
cindy toy
Level 7
Level 7
Hi GP,
Thank you for your question.  However, the Small Business Support Community is limited to Cisco Small Business Products.
Your question below may relate to a Cisco Classic Product which our community would not be able to help you with.
The best area for you to post your question would be at the Cisco NetPro forums: https://supportforums.cisco.com/index.jspa
Best regards,
Cindy
Cindy Toy
Small Business Community Manager
Customer Advocacy
Cisco Systems, Inc.
www.cisco.com/go/smallbizsupport
Regards, Cindy If my response answered your question, please mark the response as answered. Thank you!
