Passing multiple VLANs across WAN
Answered Question
Feb 4th, 2010
  • Silver, 250 points or more
Hi all,
From my reading thus far, I know that one can use 802.1 Q tunnel to pass VLAN across a WAN link. My questions: is it possible to pass more than one VLAN across a WAN link? Does anyone has a sample configuration?
Correct Answer by Jerry Ye about 7 years 5 months ago
Yes, you can do EoMPLS or L2TPv3.
Regard,
jerry
Overall Rating: 5 (1 ratings)
Correct Answer
Jerry Ye Thu, 02/04/2010 - 07:56
  • Cisco Employee,
Regard,
jerry
Tshi M Thu, 02/04/2010 - 08:10
I am more thinking of the L2TPv3 route: Would this work?
Location A:
int G9/48
description Link to Location A
switchport
switchport trunk encap dot1q
switchport trunk native vlan 1001
switchport trunk allowed 5,7,13-15,21,35,99
switchport mode trunk
Location B:
int G9/48
description Link to Location B
switchport
I also think that the service provider has to support this. Correct?
Tshi M Thu, 02/04/2010 - 08:18
Yes, we are thinking of ordering a fiber link with our SP and connecting it to our 6509...
Jerry Ye Thu, 02/04/2010 - 08:27
  • Cisco Employee,
Then your ISP will need to support 802.1q on their network. 6500 doesn't support L2TPv3.
jerry
Tshi M Thu, 02/04/2010 - 08:31
Thanks. What can I use with the 6509. Would that sample configuration work with the 6509 if the SP supports 802.1Q?
Jerry Ye Thu, 02/04/2010 - 08:48
  • Cisco Employee,
If your ISP supports some type of LAN service to allow 802.1q, you just have to configure the ports as trunk ports, that is it.
jerry
loworderbit Thu, 02/04/2010 - 09:26
Perhaps 802.1QinQ might work?  It would assume that you have a trunk available from your isp.
Dave
