Welcome to the Community!
The Community is a hub for connecting with your peers and Cisco specialists to ask for help, share your expertise, build your network, and grow professionally.
New Here? Click here to learn more and get started.
1927539members
1240311discussions
Community Activity
How Do I Communicate With A Live Person At Singapore 𝗔irlines? #USA #
How do I connect to Singapore 헔헶헿헹헶헻헲혀?퓣퓸 퓬퓸퓷퓷퓮퓬퓽 with Singapore 퐀퐢퐫퐥퐢퐧퐞퐬, explore multiple channels like their website, mobile app, or customer service hotline at +ퟭ-ퟴퟬퟰ-ퟴퟴퟲ-ퟬퟴퟴퟲ  or +ퟭ-ퟴퟬퟰ-ퟴퟴퟲ-ퟬퟴퟴퟲ . Booking 헙헹헶헴헵혁s, managing reservations, and acce...
great84 by Level 1
  • 3 Views
  • 0 replies
UCCX Call redirect to voicemail issue
Hi, We have some scripts that send a call redirect to a user's voicemail greeting and this works fine, using the call redirect step (destination = VM pilot, Called address reset to user's Ext.).The current set up from CUCM to Unity is SCCP, and I've ...
Swithc oonfig
I am using a 3750 switch and going through a Sidewinder G2 firewall. Thefirewall only has its startup config on it with and Internal IP address (.1)which will be the internal gateway. My switch has VLAN2 config of .2. I can ping from my switch to the...
Need help on how to setup static routing Using CBS350
Hi, I'm trying to configure a connection between 2 house network as in the image and I need help on how to configure the switch to make all device able to connect to device on the other network. I've check both router and see static routing menu on w...
Capslock by Level 1
  • 54 Views
  • 1 replies
Setting UP a SECOND ASA5506-x firewall
Hello, I successfully set up/configured my first ASA device. I just purchased as second 5506 and am wondering about how compatible or incompatible the bkup configuration files I’ve saved from the first device are gonna be with the second ASA. It ment...
Problems with SNMP on the ASA 5555-X
Hello everyone,I have a CISCO ASA 5555-X configured in multi-context mode and I want to monitor it via SNMP.However, I can't find the MIB files for this device.How can I get them?I don't have access to ftp://ftp.cisco.com/pub/mibs/supportlists/asa/as...
vsmjoao14 by Level 1
  • 81 Views
  • 2 replies
Resolved! Cisco 9124AX as WGB on non-DFS channels
We have this Cisco 9124AX for the European market, configured as WGB (work group bridge) and we would like to use it on non-DFS channels on the 5GHz band.However, we are not allowed to add any such channels to the scan list, we can only use channels ...
Renewall of Admin Certificate
I have to renew the admin certificate in a pair of ISE nodes (Prim / Sec) on Version 3.2.0.542 Patch 4. Currently both devices have the same admin cert that expires in little over 3 weeks. All the names and IPs in this thread are placeholders. I gene...
Sergio C by Level 1
  • 89 Views
  • 4 replies
C9800-80 in HA cannot install APSP6
Hello everyone,I'm trying to figure out a frustrating issue. Attempting an install of APSP6 keeps bombing out and I'm unsure what steps to take next. Software: Version 17.09.04aROM: 17.3(3r)Error in question:  Dec 13 21:21:01 Eastern: %INSTALL-3-OPER...
Installing Secure Client (5.x) AND Any Connect (4.x) on 1 computer
I have a weird situation I need to connect to two sepaate VPN (not at the same time).One of these requires Cisco Secure Client 5.x the second works with Any Connect 4.x.I have Cisco Secure Client 5.x installed, if i try connecting to the VPN that use...
marcobat by Level 1
  • 106 Views
  • 1 replies
