Firewall: SIP dynamic audio ports connections
Feb 4th, 2010
Is there away of creating a policy-map that allows UDP ports to open up dynamically for 10000-49999 ratherthan open them up in an ACL? After a call is made thru the firewall, it uses UDP ports 10000-49999. I don't want to open up all these ports.
johng231 Fri, 02/05/2010 - 07:10
I've gotten it to work by creating the following policy:
access-list 100 line 1 extended permit udp any any range 10000 49999
class-map sip_audio_port
match access-list 100
policy-map sip_policy
class sip_audio_port
  inspect sip
service-policy sip_policy interface inside
service-policy sip_policy interface VOICE
Why should I have to specify the high range when SIP is enabled by default for the inspect policy? The inspect policy for SIP should know how to open up these high ports automatically.
